Datasheet Wago 734-565 — Даташит
Розетка под пайку THT; 0.9 x 0.9 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 3,81 мм; 5-пол.
THT FEMALE HEADER; 0.9 X 0.9 MM | |||
734565-000 TE Connectivity | 66 ₽ | ||
734-565 Wago | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 14.65 mm / 0.577 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.058 MJ |
GTIN | 4045454120917 |
Height | 14.3 mm / 0.563 inch |
Height from the surface | 10.5 mm / 0.413 inch |
Material group | I |
Mismating protection | Yes |
Number of Poles | 5 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 3.81 mm (0.15 inch) |
Rated current | 10 A |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.9 x 0.9 mm |
Solder pin length | 3.8 мм |
Total number of connection points | 5 |
Total number of potentials | 5 |
Вес | 2.85 г |
Ширина | 20.55 mm / 0.809 inch |
Серия: 734 (100 из 708)
- 734-505/037-000 734-506 734-506/037-000 734-508 734-508/037-000 734-509 734-509/037-000 734-510 734-510/037-000 734-512 734-512/037-000 734-514 734-514/037-000 734-515 734-515/037-000 734-516 734-516/037-000 734-520 734-520/037-000 734-532 734-532/037-000 734-533 734-533/037-000 734-534 734-534/037-000 734-535 734-535/037-000 734-536 734-536/037-000 734-537 734-537/037-000 734-538 734-538/037-000 734-539 734-539/037-000 734-540 734-540/037-000 734-541 734-541/037-000 734-542 734-542/037-000 734-543 734-543/037-000 734-544 734-544/037-000 734-546 734-546/037-000 734-548 734-548/037-000 734-550 734-550/037-000 734-554 734-554/037-000 734-562 734-562/037-000 734-563 734-563/037-000 734-564 734-564/037-000 734-565 734-565/037-000 734-566 734-566/037-000 734-568 734-568/037-000 734-569 734-569/037-000 734-570 734-570/037-000 734-572 734-572/037-000 734-574 734-574/037-000 734-575 734-575/037-000 734-576 734-576/037-000 734-580 734-580/037-000 734-602 734-603 734-604 734-605 734-606 734-607 734-608 734-609 734-610 734-611 734-612 734-632 734-633 734-634 734-635 734-636 734-638 734-639 734-640 734-642 734-671
