Datasheet Wago 735-123 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,81 мм; 3-полюсный; ПРОВОД НАЖИМА
![]() 9 предложений от 6 поставщиков PCB TERMINAL BLOCK; PUSH-BUTTON; | |||
10-735123-11P**MS Amphenol | 2 630 ₽ | ||
735-123/001-000 Wago | по запросу | ||
735-123/001-000 | по запросу | ||
735-123 | по запросу |
Actuation type | Push-button |
Цвет | orange |
Conductor entry angle to the PCB | 90 ° |
Connection technology | PUSH WIRE® |
Country of origin | CH |
Габариты: глубина | 10.8 mm / 0.425 inch |
Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1 mm² |
Fire load | 0.032 MJ |
GTIN | 4044918792615 |
Height | 21.9 mm / 0.862 inch |
Height from the surface | 18.4 mm / 0.724 inch |
Material group | I |
Number of Poles | 3 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 3.81 mm / 0.15 inch |
Rated current | 10 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.4 x 0.9 mm |
Solder pin length | 3.5 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Вес | 2.394 г |
Ширина | 11.43 mm / 0.45 inch |
Серия: 735 (18)
- PCB Interconnect
