Datasheet Wago 735-126/001-000 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,81 мм; 4-полюсный; ПРОВОД НАЖИМА
PCB TERMINAL BLOCK; PUSH-BUTTON; | |||
| 735-126/001-000 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry angle to the PCB | 90 ° |
| Connection technology | PUSH WIRE® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 10.8 mm / 0.425 inch |
| Drilled hole diameter (tolerance) | 1(+ 0.1) мм |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 1 mm² |
| Fire load | 0.06 MJ |
| GTIN | 4044918792783 |
| Height | 21.9 mm / 0.862 inch |
| Height from the surface | 18.4 mm / 0.724 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 3.81 mm / 0.15 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.4 x 0.9 mm |
| Solder pin length | 3.5 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 4 |
| Вес | 3.789 г |
| Ширина | 22.56 mm / 0.888 inch |
Серия: 735 (18)
- PCB Interconnect
735126/001000, 735 126/001 000
