Datasheet Wago 736-104 — Даташит
Двухуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 2 x 4-полюсный; CAGE CLAMP
![]() 21 предложений от 11 поставщиков Axial Lead and Cartridge Fuses - Subminiature Glass Body | |||
FXO-HC736-104 IDT | 2 670 ₽ | ||
RJSSE736104 | по запросу | ||
FXO-HC736-104 Fox Electronics | по запросу | ||
WAGO 736-104 | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 21 mm / 0.827 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.149 MJ |
GTIN | 4044918913218 |
Height | 30.5 mm / 1.201 inch |
Height from the surface | 26.5 mm / 1.043 inch |
Material group | I |
Number of Poles | 4 |
Number of levels | 2 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 21 A |
Rated current (2) | 21 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated impulse voltage (II / 2) 2 | 4 kV |
Rated impulse voltage (III / 2) 2 | 4 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (II / 2) 2 | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 2) 2 | 320 В |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 320 В |
Ratings according to 2 | IEC/EN 60664-1 |
Ratings note | Between the modules |
Ratings note 2 | Between the decks |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 8 |
Total number of potentials | 8 |
Вес | 9.487 г |
Ширина | 21 mm / 0.827 inch |
Серия: 736 (89)
- 736-102 736-103 736-104 736-106 736-107/000-016 736-108 736-112 736-116 736-124 736-202 736-203 736-204 736-206 736-208 736-212 736-216 736-224 736-302 736-303 736-304 736-306 736-308 736-312 736-316 736-324 736-402 736-403 736-404 736-406 736-408 736-412 736-415 736-416 736-424 736-502 736-503 736-504 736-506 736-508 736-510 736-512 736-516 736-552 736-553 736-554 736-556 736-558 736-562 736-566 736-602 736-603 736-604 736-606 736-608 736-612 736-616 736-652 736-653 736-654 736-656 736-658 736-660 736-662 736-665 736-666 736-702 736-703 736-704 736-706 736-708 736-712 736-752 736-753 736-754 736-756 736-758 736-762 736-802 736-803 736-804 736-806 736-808 736-812 736-852 736-853 736-854 736-856 736-858 736-862
- PCB Interconnect
