Datasheet Wago 736-302 — Даташит
Серия736
Модель736-302
Двухуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 2 x 2-полюсный; CAGE CLAMP
модуль Соединители, Conn Mod Jack 6p6c r/a Shld
241 ₽
RJHSE736302
Amphenol
246 ₽
736-302
МосЧип
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина21 mm / 0.827 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.08 MJ
GTIN4044918913973
Height30.5 mm / 1.201 inch
Height from the surface26.5 mm / 1.043 inch
Material groupI
Number of Poles2
Number of connection types1
Number of levels2
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)630 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)250 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points4
Total number of potentials4
Вес4.951 г
Ширина11.16 mm / 0.439 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 736-302
