Datasheet Wago 736-512 — Даташит
Серия736
Модель736-512
Двухуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 7,5 мм; 2 x 12-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина21 mm / 0.827 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.531 MJ
GTIN4044918914611
Height30.5 mm / 1.201 inch
Height from the surface26.5 mm / 1.043 inch
Material groupI
Number of Poles12
Number of connection types1
Number of levels2
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)1000 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)630 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)400 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points24
Total number of potentials24
Вес31.214 г
Ширина88.5 mm / 3.484 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 736-512
