Datasheet Wago 736-603 — Даташит
Серия736
Модель736-603
Двухуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 7,62 мм; 2 x 3-полюсный; CAGE CLAMP
5 предложений от 5 поставщиков
Вибратор, 60.3MHz ±25ppm 3.3V 30pF 6Pin
FXO-HC736-60.3
IDT
1 647 ₽
FXO-HC736-60.3
Fox Electronics
1 655 ₽
FXO-HC736-60.3
IDT
1 771 ₽
LifeElectronics
FXO-HC736-60.3
Fox Electronics
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина21 mm / 0.827 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.138 MJ
GTIN4044918914673
Height30.5 mm / 1.201 inch
Height from the surface26.5 mm / 1.043 inch
Material groupI
Number of Poles3
Number of connection types1
Number of levels2
PCB contactTHT
Pin spacing7.62 mm (0.3 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)1000 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)630 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)400 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points6
Total number of potentials6
Вес8.003 г
Ширина21.24 mm / 0.836 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 736-603
