Datasheet Wago 737-102 — Даташит
Трехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 3 x 2-полюсный; CAGE CLAMP
| 737-102, 3 уров. клемма для печатных плат, 3 вывода под пайку, в линию 2X3-конт., шаг 5 мм | |||
| 737-102 Wago Оф. дистрибьютор | 478 ₽ | ||
| 737-102 Wago | по запросу | ||
| 737102-15 | по запросу | ||
| 737102-13 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 31 mm / 1.22 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.14 MJ |
| GTIN | 4045454021566 |
| Height | 44 mm / 1.732 inch |
| Height from the surface | 40 mm / 1.575 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 3 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 21 A |
| Rated current (2) | 21 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (II / 2) 2 | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated impulse voltage (III / 2) 2 | 4 kV |
| Rated impulse voltage (III / 3) 2 | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (II / 2) 2 | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 2) 2 | 320 В |
| Rated voltage (III / 3) | 250 В |
| Rated voltage (III / 3) 2 | 320 В |
| Ratings according to 2 | IEC/EN 60664-1 |
| Ratings note | Between the modules |
| Ratings note 2 | Between the decks |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Вес | 8.967 г |
| Ширина | 11 mm / 0.433 inch |
Серия: 737 (85)
- 737-102 737-103 737-104 737-106 737-108 737-112 737-116 737-124 737-202 737-203 737-204 737-206 737-208 737-212 737-216 737-224 737-302 737-303 737-304 737-306 737-308 737-312 737-316 737-324 737-402 737-403 737-404 737-406 737-408 737-412 737-416 737-424 737-502 737-503 737-504 737-505 737-506 737-508 737-512 737-516 737-552 737-553 737-554 737-556 737-558 737-562 737-566 737-602 737-603 737-604 737-606 737-608 737-612 737-616 737-652 737-653 737-654 737-656 737-658 737-662 737-666 737-702 737-703 737-704 737-706 737-708 737-712 737-752 737-753 737-754 737-756 737-758 737-762 737-802 737-803 737-804 737-806 737-808 737-812 737-852 737-853 737-854 737-856 737-858 737-862
- PCB Interconnect
 Купить 737-102 на РадиоЛоцман.Цены
