Линейка продуктов KEEN SIDE
Datasheet Wago 737-312 — Даташит
Серия737
Модель737-312
Трехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 3 x 12-полюсный; CAGE CLAMP
5 предложений от 5 поставщиков
TRIPLE-DECK PCB TERMINAL BLOCK;
316 ₽
Hi-Tech Circuit Group
B737312
TradeElectronics
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина31 mm / 1.22 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.721 MJ
GTIN4045454022259
Height44 mm / 1.732 inch
Height from the surface40 mm / 1.575 inch
Material groupI
Number of Poles12
Number of connection types1
Number of levels3
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)630 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)250 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points36
Total number of potentials36
Вес49.864 г
Ширина61.96 mm / 2.439 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 737-312
