Datasheet Wago 737-402 — Даташит
Серия737
Модель737-402
Трехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 3 x 2-полюсный; CAGE CLAMP
25 предложений от 10 поставщиков
Модули Входа Питания , AMPHENOL INDUSTRIAL 10-737402-138 Power Entry Connector, RADSERT Series, Plug, 60A, Panel Mount, Screw
Amphenol
150 ₽
Amphenol
150 ₽
10-737402-138
Amphenol
от 405 ₽
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина31 mm / 1.22 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.141 MJ
GTIN4045454022952
Height44 mm / 1.732 inch
Height from the surface40 mm / 1.575 inch
Material groupI
Number of Poles2
Number of connection types1
Number of levels3
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)630 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)250 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, staggered
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points6
Total number of potentials6
Вес9.022 г
Ширина11.16 mm / 0.439 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 737-402
