Datasheet Wago 737-612 — Даташит
Серия737
Модель737-612
Трехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 7,62 мм; 3 x 12-полюсный; CAGE CLAMP
Вентиляторы, Воздуходувки и Аксессуары, Fan Accessories Axial Impeller/154mm 22 Degree/"A"Airflow
EBM-Papst Industries
313 ₽
73761-2-3634
Hi-Tech Circuit Group
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина31 mm / 1.22 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.93 MJ
GTIN4045454018672
Height44 mm / 1.732 inch
Height from the surface40 mm / 1.575 inch
Material groupI
Number of Poles12
Number of connection types1
Number of levels3
PCB contactTHT
Pin spacing7.62 mm (0.3 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)1000 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)630 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)400 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points36
Total number of potentials36
Вес56.75 г
Ширина89.82 mm / 3.536 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 737-612
