Datasheet Wago 737-856 — Даташит
Серия737
Модель737-856
Клеммная колодка для печатной платы с тремя уровнями; 2,5 мм²; Шаг контактов 10,16 мм; 3 x 6-полюсный; CAGE CLAMP
МосЧип
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина31 mm / 1.22 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.578 MJ
GTIN4045454019938
Height44 mm / 1.732 inch
Height from the surface40 mm / 1.575 inch
Material groupI
Number of Poles6
Number of connection types1
Number of levels3
PCB contactTHT
Pin spacing10.16 mm (0.4 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2)8 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)1000 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)630 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, staggered
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points18
Total number of potentials18
Вес31.817 г
Ширина56.8 mm / 2.236 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 737-856
