Datasheet Wago 737-858 — Даташит
Серия737
Модель737-858
Клеммная колодка для печатной платы с тремя уровнями; 2,5 мм²; Шаг контактов 10,16 мм; 3 x 8-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина31 mm / 1.22 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.776 MJ
GTIN4045454019945
Height44 mm / 1.732 inch
Height from the surface40 mm / 1.575 inch
Material groupI
Number of Poles8
Number of connection types1
Number of levels3
PCB contactTHT
Pin spacing10.16 mm (0.4 inch)
Rated current21 A
Rated current (2)21 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2)8 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)1000 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)630 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, staggered
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points24
Total number of potentials24
Вес42.573 г
Ширина77.12 mm / 3.036 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 737-858
