Datasheet Wago 738-102 — Даташит
Четырехъярусная клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 4 x 2-полюсный; CAGE CLAMP
![]() 12 предложений от 12 поставщиков Вентиляторы, Воздуходувки и Аксессуары, IQ fan axial impeller, 230mm 22deg, flow v | |||
73810-2-3634 | 723 ₽ | ||
73810-2-3634 EBM-Papst Industries | 1 423 ₽ | ||
73810-2-3634 | 1 437 ₽ | ||
73810-2-3634 | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 37.5 mm / 1.476 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.192 MJ |
GTIN | 4045454161897 |
Height | 48.2 mm / 1.898 inch |
Height from the surface | 44.2 mm / 1.74 inch |
Material group | I |
Number of Poles | 2 |
Number of levels | 4 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 18 A |
Rated current (2) | 18 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated impulse voltage (II / 2) 2 | 4 kV |
Rated impulse voltage (III / 2) 2 | 4 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (II / 2) 2 | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 2) 2 | 320 В |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 320 В |
Ratings according to 2 | IEC/EN 60664-1 |
Ratings note | Between the modules |
Ratings note 2 | Between the decks |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 8 |
Total number of potentials | 8 |
Вес | 12.979 г |
Ширина | 11 mm / 0.433 inch |
Серия: 738 (32)
- PCB Interconnect
