Datasheet Wago 738 — Даташит
Серия738
Datasheet Wago 738
Вентиляторы, Воздуходувки и Аксессуары, IQ fan axial impeller, 230mm 22deg, flow v
EBM-Papst Industries
603 ₽
Эиком
1 470 ₽
Элитан
1 784 ₽
Parameters / Models738-102
738-102
738-103
738-103
738-104
738-104
738-106
738-106
738-108
738-108
738-112
738-112
738-116
738-116
738-124
738-124
738-202
738-202
738-203
738-203
738-204
738-204
738-206
738-206
738-208
738-208
738-212
738-212
738-216
738-216
738-224
738-224
738-302
738-302
738-303
738-303
738-304
738-304
738-306
738-306
738-308
738-308
738-312
738-312
738-316
738-316
738-324
738-324
738-402
738-402
738-403
738-403
738-404
738-404
738-406
738-406
738-408
738-408
738-412
738-412
738-416
738-416
738-424
738-424
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraygraygraygraygraygraygraygraygraygraygraygraygraygraygrayorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorangeorange
Conductor entry angle to the PCB, °4545454545454545454545454545454545454545454545454545454545454545
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPL
Габариты: глубина37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch37.5 mm / 1.476 inch
Drilled hole diameter (tolerance), мм1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)1.3(+ 0.1)
Fine-stranded conductor0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²0.25 … 1.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²
Fire load, MJ0.1920.2710.350.5080.6660.9821.2981.930.1920.2710.350.5080.6660.9821.2981.930.1930.2730.3530.5130.6730.9931.3131.9530.1930.2730.3530.5130.6730.9931.3131.953
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN40454541618974045454160876404545416190340454541619104045454160951404545416102640454541619964045454161088404545416014240454541617984045454161804404545416173640454541618354045454159863404545415988740454541617504045454159580404545416112540454541620304045454162078404545416119440454541621224045454161224404545416150740454541617674045454159894404545415990040454541599244045454159948404545415995540454541617744045454159986
Height48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch48.2 mm / 1.898 inch
Height from the surface44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch44.2 mm / 1.74 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
Number of Poles23468121624234681216242346812162423468121624
Number of connection types11111111111111111111111111111111
Number of levels44444444444444444444444444444444
Number of solder pins per potential11111111111111111111111111111111
PCB contactTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHT
Pin spacing5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5 mm (0.197 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)5.08 mm (0.2 inch)
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A1818181818181818181818181818181818181818181818181818181818181818
Rated current (2), A1818181818181818181818181818181818181818181818181818181818181818
Rated impulse voltage (II / 2), kV44444444444444444444444444444444
Rated impulse voltage (II / 2) 2, kV44444444444444444444444444444444
Rated impulse voltage (III / 2), kV44444444444444444444444444444444
Rated impulse voltage (III / 2) 2, kV44444444444444444444444444444444
Rated impulse voltage (III / 3), kV44444444444444444444444444444444
Rated impulse voltage (III / 3) 2, kV44444444444444444444444444444444
Rated voltage (II / 2), В630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630
Rated voltage (II / 2) 2, В630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630630
Rated voltage (III / 2), В320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320
Rated voltage (III / 2) 2, В320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320
Rated voltage (III / 3), В250250250250250250250250250250250250250250250250250250250250250250250250250250250250250250250250
Rated voltage (III / 3) 2, В320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320320
Ratings according to 2IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1IEC/EN 60664-1
Ratings noteBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modulesBetween the modules
Ratings note 2Between the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decksBetween the decks
Solder pin arrangementwithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, in linewithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggeredwithin the terminal block, staggered
Solder pin dimensions0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm0.7 x 0.7 mm
Solder pin length, мм44444444444444444444444444444444
Solid conductor0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG0.08 … 2.5 mm² / 28 … 12 AWG
Strip length5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch5 … 6 mm / 0.2 … 0.24 Inch
Total number of connection points812162432486496812162432486496812162432486496812162432486496
Total number of potentials812162432486496812162432486496812162432486496812162432486496
Вес, г12.97918.90924.83936.69948.55972.27995.999143.43912.99718.93624.87536.75348.63172.38796.143143.65513.01618.97624.93636.85648.77672.61696.456144.13613.03419.00324.97236.9148.84872.72496.6144.352
Ширина11 mm / 0.433 inch16 mm / 0.63 inch21 mm / 0.827 inch31 mm / 1.22 inch41 mm / 1.614 inch61 mm / 2.402 inch81 mm / 3.189 inch121 mm / 4.764 inch11 mm / 0.433 inch16 mm / 0.63 inch21 mm / 0.827 inch31 mm / 1.22 inch41 mm / 1.614 inch61 mm / 2.402 inch81 mm / 3.189 inch121 mm / 4.764 inch11.16 mm / 0.439 inch16.24 mm / 0.639 inch21.32 mm / 0.839 inch31.48 mm / 1.239 inch41.64 mm / 1.639 inch61.96 mm / 2.439 inch82.28 mm / 3.239 inch122.92 mm / 4.839 inch11.16 mm / 0.439 inch16.24 mm / 0.639 inch21.32 mm / 0.839 inch31.48 mm / 1.239 inch41.64 mm / 1.639 inch61.96 mm / 2.439 inch82.28 mm / 3.239 inch122.92 mm / 4.839 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 738
