Datasheet Wago 738-108 — Даташит
Серия738
Модель738-108
Четырехъярусная клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 4 x 8-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина37.5 mm / 1.476 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.666 MJ
GTIN4045454160951
Height48.2 mm / 1.898 inch
Height from the surface44.2 mm / 1.74 inch
Material groupI
Number of Poles8
Number of connection types1
Number of levels4
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current18 A
Rated current (2)18 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)630 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)250 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points32
Total number of potentials32
Вес48.559 г
Ширина41 mm / 1.614 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 738-108
