Datasheet Wago 738-212 — Даташит
Четырехъярусная клеммная колодка для печатных плат; 2,5 мм²; Шаг контактов 5 мм; 4 x 12-полюсный; CAGE CLAMP
Купить 738-212 на РадиоЛоцман.Цены — от 174 до 321 ₽ 6 предложений от 6 поставщиков , Fan Accessories Axial Impeller "V" Airflow, 200mm | |||
73821-2-3634 EBM-Papst Industries | 174 ₽ | ||
738-2-1/2 | по запросу | ||
73821-2-3634 | по запросу | ||
738-212 Wago | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 37.5 mm / 1.476 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.982 MJ |
GTIN | 4045454159863 |
Height | 48.2 mm / 1.898 inch |
Height from the surface | 44.2 mm / 1.74 inch |
Material group | I |
Number of Poles | 12 |
Number of levels | 4 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 18 A |
Rated current (2) | 18 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated impulse voltage (II / 2) 2 | 4 kV |
Rated impulse voltage (III / 2) 2 | 4 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (II / 2) 2 | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 2) 2 | 320 В |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 320 В |
Ratings according to 2 | IEC/EN 60664-1 |
Ratings note | Between the modules |
Ratings note 2 | Between the decks |
Solder pin arrangement | within the terminal block, staggered |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 48 |
Total number of potentials | 48 |
Вес | 72.387 г |
Ширина | 61 mm / 2.402 inch |
Серия: 738 (32)
- PCB Interconnect
