Datasheet Wago 738-304 — Даташит
Серия738
Модель738-304
Четырехъярусная клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 4 x 4-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветorange
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина37.5 mm / 1.476 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.353 MJ
GTIN4045454162030
Height48.2 mm / 1.898 inch
Height from the surface44.2 mm / 1.74 inch
Material groupI
Number of Poles4
Number of connection types1
Number of levels4
PCB contactTHT
Pin spacing5.08 mm (0.2 inch)
Rated current18 A
Rated current (2)18 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (III / 2) 24 kV
Rated impulse voltage (III / 3) 24 kV
Rated voltage (II / 2)630 В
Rated voltage (II / 2) 2630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 2) 2320 В
Rated voltage (III / 3)250 В
Rated voltage (III / 3) 2320 В
Ratings according to 2IEC/EN 60664-1
Ratings noteBetween the modules
Ratings note 2Between the decks
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.7 x 0.7 mm
Solder pin length4 мм
Total number of connection points16
Total number of potentials16
Вес24.936 г
Ширина21.32 mm / 0.839 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 738-304
