Datasheet Wago 738-312 — Даташит
Четырехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 4 x 12-полюсный; CAGE CLAMP
Купить 738-312 на РадиоЛоцман.Цены — от 4 217 до 4 514 ₽QUADRUPLE-DECK PCB TERMINAL BLOC | |||
| FXO-PC738-312 Fox Electronics | 4 217 ₽ | ||
| FXO-PC738-312 IDT | 4 514 ₽ | ||
| FXO-PC738-312 Fox Electronics | по запросу | ||
| 738-312 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 37.5 mm / 1.476 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.993 MJ |
| GTIN | 4045454162122 |
| Height | 48.2 mm / 1.898 inch |
| Height from the surface | 44.2 mm / 1.74 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 4 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 18 A |
| Rated current (2) | 18 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (II / 2) 2 | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated impulse voltage (III / 2) 2 | 4 kV |
| Rated impulse voltage (III / 3) 2 | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (II / 2) 2 | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 2) 2 | 320 В |
| Rated voltage (III / 3) | 250 В |
| Rated voltage (III / 3) 2 | 320 В |
| Ratings according to 2 | IEC/EN 60664-1 |
| Ratings note | Between the modules |
| Ratings note 2 | Between the decks |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 48 |
| Total number of potentials | 48 |
| Вес | 72.616 г |
| Ширина | 61.96 mm / 2.439 inch |
Серия: 738 (32)
- PCB Interconnect
