Datasheet Wago 739-306/001-000 — Даташит
Серия739
Модель739-306/001-000
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 6-полюсный; CAGE CLAMP; зажимной хомут
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originPL
Габариты: глубина13.4 mm / 0.528 inch
Fine-stranded conductor0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1.5 mm²
Fire load0.094 MJ
GTIN4017332750196
Height15.7 mm / 0.618 inch
Height from the surface12.3 mm / 0.484 inch
Material groupI
Mounting typeMounting flange
Number of Poles6
Number of connection types1
Number of levels1
PCB contactTHT
Rated current17.5 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)160 В
Solder pin dimensions0.6 x 0.8 mm
Solder pin length3.4 мм
Solid conductor0.08 … 1.5 mm² / 28 … 14 AWG
Total number of connection points6
Total number of potentials6
Type of mountingPanel mounting
Вес4.752 г
Ширина35.8 mm / 1.409 inch
  • PCB Interconnect
739306/001000, 739 306/001 000
На английском языке: Datasheet Wago 739-306/001-000
