Datasheet Wago 739-339 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,81 мм; 9-полюсный; CAGE CLAMP
| PCB TERMINAL BLOCK; 1.5 MM; PIN | |||
| 739-339 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry angle to the PCB | 90 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13.4 mm / 0.528 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.121 MJ |
| GTIN | 4044918301794 |
| Height | 15.7 mm / 0.618 inch |
| Height from the surface | 12.3 mm / 0.484 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 9 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.81 mm (0.15 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 17.5 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 500 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 200 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.6 x 0.8 mm |
| Solder pin length | 3.4 мм |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 9 |
| Total number of potentials | 9 |
| Вес | 6.317 г |
| Ширина | 35.79 mm / 1.409 inch |
Серия: 739 (97)
- 739-102 739-103 739-104 739-105 739-106 739-107 739-108 739-109 739-110 739-112 739-115 739-116 739-124 739-152 739-153 739-154 739-155 739-156 739-157 739-158 739-159 739-160 739-162 739-166 739-174 739-202 739-203 739-204 739-205 739-206 739-207 739-208 739-209 739-210 739-212 739-232 739-233 739-234 739-235 739-236 739-237 739-238 739-239 739-240 739-242 739-302 739-302/001-000 739-303 739-303/001-000 739-304 739-304/001-000 739-305 739-305/001-000 739-306 739-306/001-000 739-307 739-307/001-000 739-308 739-308/001-000 739-309 739-309/001-000 739-310 739-310/001-000 739-312 739-312/001-000 739-3202 739-3203 739-3204 739-3205 739-3206 739-3207 739-3208 739-3209 739-3210 739-3211 739-3212 739-332 739-332/001-000 739-333 739-333/001-000 739-334 739-334/001-000 739-335 739-335/001-000 739-336 739-336/001-000 739-337 739-337/001-000 739-338 739-338/001-000 739-339 739-339/001-000 739-340 739-340/001-000 739-340/100-000/001-000 739-342 739-342/001-000
- PCB Interconnect
