Datasheet Wago 740-112 — Даташит
Клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5 мм; 12-полюсный; CAGE CLAMP
740-112 Wago | по запросу | ||
C7401-12 | по запросу | ||
C740112 | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 11.1 mm / 0.437 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.24 MJ |
GTIN | 4045454142513 |
Height | 23.3 mm / 0.917 inch |
Height from the surface | 18.2 mm / 0.717 inch |
Material group | I |
Number of Poles | 12 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 300 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.8 x 1 mm |
Solder pin length | 5.1 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
Total number of connection points | 12 |
Total number of potentials | 12 |
Вес | 16.542 г |
Ширина | 60 mm / 2.362 inch |
Серия: 740 (20)
- PCB Interconnect
