Datasheet Wago 742 — Даташит
Производитель | Wago |
Серия | 742 |
![]() 7 предложений от 7 поставщиков Комплектующие для клеммных колодок Insul Inter Jmpr 6mm 10pole | |||
742-100 Wago | 18 ₽ | ||
CA742/100 Altech | 3 057 ₽ | ||
CA742/100 Altech | по запросу | ||
Parameters / Models | 742-100![]() | 742-101![]() | 742-106![]() | 742-111![]() | 742-116![]() | 742-121![]() | 742-124![]() | 742-126![]() | 742-128![]() | 742-150![]() | 742-151![]() | 742-152![]() | 742-153![]() | 742-156![]() | 742-158![]() | 742-161![]() | 742-163![]() | 742-166![]() | 742-168![]() | 742-171![]() | 742-174![]() | 742-176![]() | 742-178![]() | 742-400![]() | 742-450![]() | 742-600![]() | 742-650![]() | 742-651![]() | 742-800![]() | 742-850![]() |
Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | ||||||||||
Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | ||||||||||
Цвет | gray | gray | orange | gray | orange | gray | blue | orange | green-yellow | gray | gray | gray | gray | orange | orange | gray | gray | orange | orange | gray | blue | orange | green-yellow, blue, gray | blue | blue | orange | orange | orange | green-yellow | green-yellow |
Conductor entry angle to the PCB, ° | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | 90 | ||||||||||
Connection technology | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | ||||||||||
Contact material | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | ||||||||||
Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | ||||||||||
Country of origin | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH |
Габариты: глубина | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 34.7 mm / 1.366 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 53.2 mm / 2.094 inch | 53.2 mm / 2.094 inch | 43.5 mm / 1.713 inch | 53.2 mm / 2.094 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 53.2 mm / 2.094 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 43.5 mm / 1.713 inch | 34.7 mm / 1.366 inch | 43.5 mm / 1.713 inch | 34.7 mm / 1.366 inch | 43.5 mm / 1.713 inch | 53.2 mm / 2.094 inch | 34.7 mm / 1.366 inch | 43.5 mm / 1.713 inch |
Drilled hole diameter (tolerance), мм | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | 1.4(+ 0.1) | ||||||||||
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | ||||||||||
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | ||||||||||
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | ||||||||||
Fire load, MJ | 0.037 | 0.073 | 0.074 | 0.064 | 0.066 | 0.06 | 0.059 | 0.06 | 0.057 | 0.048 | 0.093 | 0.061 | 0.116 | 0.096 | 0.117 | 0.087 | 0.107 | 0.088 | 0.111 | 0.08 | 0.081 | 0.082 | 0.08 | 0.037 | 0.048 | 0.037 | 0.049 | 0.06 | 0.011 | 0.049 |
Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | ||||||||||
GTIN | 4017332303903 | 4045454265618 | 4045454232375 | 4045454232139 | 4045454232160 | 4045454225247 | 4045454226053 | 4045454225278 | 4045454225292 | 4017332412445 | 4045454265212 | 4017332412520 | 4045454232597 | 4045454265236 | 4045454232641 | 4045454265175 | 4045454232221 | 4045454265199 | 4045454232276 | 4044918472999 | 4044918473040 | 4044918473101 | 4045454266974 | 4017332303910 | 4017332557849 | 4017332303927 | 4017332412506 | 4017332412537 | 4017332303934 | 4017332555937 |
Height | 23.2 mm / 0.913 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 23.2 mm / 0.913 inch | 27.2 mm / 1.071 inch | 23.2 mm / 0.913 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 27.2 mm / 1.071 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch |
Height from the surface | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | 23.2 mm / 0.913 inch | ||||||||||
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | ||||||||||
Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | ||||||||||
Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | ||||||||||
Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | ||||||||||
Nominal current (block arrangement), A | 10 | 10 | 10 | 10 | 10 | 10 | ||||||||||||||||||||||||
Nominal current (individual arrangement), A | 15 | 15 | 15 | 15 | 15 | 15 | ||||||||||||||||||||||||
Number of Poles | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||
Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||
Number of solder pins per potential | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | ||||||||||
PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | ||||||||||
Pin spacing | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5.08 mm (0.2 inch) | 5 mm (0.197 inch) | ||||||||||
Product Group | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) |
Rated current, A | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | ||||||||||||||||
Rated impulse voltage (II / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | ||||||||||
Rated impulse voltage (III / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | ||||||||||
Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | ||||||||||
Rated voltage (II / 2), В | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | ||||||||||
Rated voltage (III / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | ||||||||||
Rated voltage (III / 3), В | 320 | 320 | 320 | 320 | 250 | 250 | 250 | 250 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | ||||||||||
Solder pin arrangement | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | within the terminal block, in line | ||||||||||
Solder pin dimensions | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | 1 x 0.8 mm | ||||||||||
Solder pin length, мм | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | ||||||||||
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | ||||||||||
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | ||||||||||
Total number of connection points | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 | 3 | 2 | 3 | 2 | 3 | 2 | 3 | 2 | 2 | 2 | 2 | ||||||||||
Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||
Type of mounting | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | snap-on type | ||||||||||||||||||||
Вес, г | 1.224 | 4.486 | 4.46 | 3.745 | 3.806 | 3.177 | 3.138 | 3.184 | 3.143 | 1.608 | 5.979 | 2.022 | 7.377 | 6.087 | 7.383 | 5.338 | 6.632 | 5.4 | 6.753 | 4.661 | 4.683 | 4.796 | 4.634 | 1.231 | 1.615 | 1.23 | 1.643 | 2.016 | 0.338 | 1.638 |
Ширина | 1.5 mm / 0.059 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 1.5 mm / 0.059 inch | 7 mm / 0.276 inch | 1.5 mm / 0.059 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 7 mm / 0.276 inch | 7.1 mm / 0.28 inch | 7 mm / 0.276 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch | 1.5 mm / 0.059 inch |
Серия: 742 (30)
- PCB Interconnect
