Datasheet Wago 742-126 — Даташит
Стекируемый клеммный блок для печатных плат; с возможностью объединения; 2,5 мм²; Шаг контактов 5,08 мм; 1-полюсный; CAGE CLAMP
STACKABLE PCB TERMINAL BLOCK; WI | |||
| 742-126 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry angle to the PCB | 60 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 34.7 mm / 1.366 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.06 MJ |
| GTIN | 4045454225278 |
| Height | 27.2 mm / 1.071 inch |
| Height from the surface | 23.2 mm / 0.913 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 1 x 0.8 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 3.184 г |
| Ширина | 7.1 mm / 0.28 inch |
Серия: 742 (30)
- PCB Interconnect
