Datasheet Wago 742-153 — Даташит
Стекируемый 3-проводной клеммный блок для печатной платы; с ножевым разъединителем; 2,5 мм²; Шаг контактов 5 мм; 1-полюсный; CAGE CLAMP
![]() STACKABLE 3-CONDUCTOR PCB TERMIN | |||
742-153 Wago | от 735 ₽ | ||
742-153 Wago | 2 533 ₽ | ||
742-153 Wago | по запросу |
Цвет | gray |
Conductor entry angle to the PCB | 90 ° |
Country of origin | CH |
Габариты: глубина | 53.2 mm / 2.094 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.116 MJ |
GTIN | 4045454232597 |
Height | 27.2 mm / 1.071 inch |
Height from the surface | 23.2 mm / 0.913 inch |
Material group | I |
Number of Poles | 1 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 1 x 0.8 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
Total number of connection points | 3 |
Total number of potentials | 1 |
Вес | 7.377 г |
Ширина | 7 mm / 0.276 inch |
Серия: 742 (30)
- PCB Interconnect
