Datasheet Wago 744 — Даташит
Производитель | Wago |
Серия | 744 |
PCB TERMINAL BLOCK; 1.5 MM; PIN | |||
744-303 Wago | по запросу | ||
744-303/000-007 Wago | по запросу |
Parameters / Models | 744-303![]() | 744-303/000-007![]() | 744-303/000-012![]() | 744-304![]() | 744-304/000-007![]() | 744-306![]() | 744-306/000-007![]() | 744-307![]() | 744-308![]() | 744-310![]() | 744-392![]() | 744-392/000-007![]() |
Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool |
Цвет | white | gray | orange | white | gray | white | gray | white | white | white | white | gray |
Connection technology | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® | PUSH WIRE® |
Contact material | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy | Copper alloy |
Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated |
Country of origin | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH |
Габариты: глубина | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch | 12.5 mm / 0.492 inch |
Drilled hole diameter (tolerance), мм | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) | 1.1(- 0.1) |
Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 |
GTIN | 4055143300520 | 4055143311908 | 4055143311915 | 4055143300537 | 4055143342605 | 4055143300544 | 4055143342612 | 4055143349925 | 4055143349918 | 4055143318051 | 4055143318075 | 4055143414616 |
Height | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch | 10.1 mm / 0.398 inch |
Height from the surface | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch | 6.6 mm / 0.26 inch |
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 |
Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C |
Material group | I | I | I | I | I | I | I | I | I | I | I | I |
Number of Poles | 3 | 3 | 3 | 4 | 4 | 6 | 6 | 7 | 8 | 10 | 2 | 2 |
Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Number of solder pins per potential | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT |
Packaging type | BOX | BOX | BOX | BOX | BOX | BOX | ||||||
Pin spacing | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) | 3.5 mm (0.138 inch) |
Rated current, A | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
Rated impulse voltage (II / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Rated impulse voltage (III / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Rated voltage (II / 2), В | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 |
Rated voltage (III / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 |
Rated voltage (III / 3), В | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 |
Solder pin arrangement | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered |
Solder pin dimensions | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm | 0.35 x 0.9 mm |
Solder pin length, мм | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 3 | 3 | 3 | 4 | 4 | 6 | 6 | 7 | 8 | 10 | 2 | 2 |
Total number of potentials | 3 | 3 | 3 | 4 | 4 | 6 | 6 | 7 | 8 | 10 | 2 | 2 |
Вес, г | 0.88 | 0.88 | 0.88 | 1.15 | 1.15 | 1.658 | 1.68 | 1.919 | 2.21 | 2.74 | 0.62 | 0.62 |
Ширина | 11.4 mm / 0.449 inch | 11.4 mm / 0.449 inch | 11.4 mm / 0.449 inch | 14.9 mm / 0.587 inch | 14.9 mm / 0.587 inch | 21.9 mm / 0.862 inch | 21.9 mm / 0.862 inch | 25.4 mm / 1 inch | 28.9 mm / 1.138 inch | 35.9 mm / 1.413 inch | 7.9 mm / 0.311 inch | 7.9 mm / 0.311 inch |
Серия: 744 (12)
- PCB Interconnect
