Datasheet Wago 744-304/000-007 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 4-полюсный; ПРОВОД PUSH
PCB TERMINAL BLOCK; 1.5 MM; PIN | |||
744-304/000-007 Wago | по запросу |
Цвет | gray |
Connection technology | PUSH WIRE® |
Contact material | Copper alloy |
Country of origin | CH |
Габариты: глубина | 12.5 mm / 0.492 inch |
Drilled hole diameter (tolerance) | 1.1(- 0.1) мм |
GTIN | 4055143342605 |
Height | 10.1 mm / 0.398 inch |
Height from the surface | 6.6 mm / 0.26 inch |
Material group | I |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THT |
Packaging type | BOX |
Rated current | 2 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.35 x 0.9 mm |
Solder pin length | 3.5 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Вес | 1.15 г |
Ширина | 14.9 mm / 0.587 inch |
Серия: 744 (12)
- PCB Interconnect
744304/000007, 744 304/000 007
