Datasheet Wago 744-310 — Даташит
Клеммная колодка для печатной платы; 1,5 мм²; Шаг контактов 3,5 мм; 10-полюсный; PUSH WIRE
| Цвет | white |
| Connection technology | PUSH WIRE® |
| Contact material | Copper alloy |
| Country of origin | CH |
| Габариты: глубина | 12.5 mm / 0.492 inch |
| Drilled hole diameter (tolerance) | 1.1(- 0.1) мм |
| GTIN | 4055143318051 |
| Height | 10.1 mm / 0.398 inch |
| Height from the surface | 6.6 mm / 0.26 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Packaging type | BOX |
| Pin spacing | 3.5 mm (0.138 inch) |
| Rated current | 2 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.35 x 0.9 mm |
| Solder pin length | 3.5 мм |
| Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 2.74 г |
| Ширина | 35.9 mm / 1.413 inch |
Серия: 744 (12)
- PCB Interconnect
