Datasheet Wago 745-358 — Даташит
Серия745
Модель745-358
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 10 мм; 8-полюсный; CAGE CLAMP; возможность объединения
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина29.1 mm / 1.146 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 4 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 4 mm²
Fire load0.78 MJ
GTIN4044918302524
Height27.5 mm / 1.083 inch
Height from the surface23 mm / 0.906 inch
Material groupI
Number of Poles8
Number of connection types1
Number of jumper slots1
Number of levels1
PCB contactTHT
Pin spacing10 mm (0.394 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)630 В
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points8
Total number of potentials8
Вес43.339 г
Ширина79.1 mm / 3.114 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 745-358
