Datasheet Wago 745-604/011-000 — Даташит
Серия745
Модель745-604/011-000
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 15 мм; 4-полюсный; CAGE CLAMP; возможность объединения
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина33.4 mm / 1.315 inch
Drilled hole diameter (tolerance)2.2(+ 0.1) мм
Fine-stranded conductor0.2 … 16 mm² / 24 … 6 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 10 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 10 mm²
Fire load0.78 MJ
GTIN4044918302982
Height33.5 mm / 1.319 inch
Height from the surface27 mm / 1.063 inch
Material groupI
Mounting typeMounting flange
Number of Poles4
Number of connection types1
Number of jumper slots1
Number of levels1
Number of solder pins per potential4
PCB contactTHT
Pin spacing15 mm (0.591 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)630 В
Solder pin dimensions1.2 x 1.6 mm
Solder pin length6.5 мм
Solid conductor0.2 … 16 mm² / 24 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points4
Total number of potentials4
Вес44.893 г
Ширина76 mm / 2.992 inch
  • PCB Interconnect
745604/011000, 745 604/011 000
На английском языке: Datasheet Wago 745-604/011-000
