Datasheet Wago 745-607/007-000 — Даташит
Серия745
Модель745-607/007-000
Клеммная колодка для печатной платы; 16 мм²; Шаг контактов 15 мм; 7-полюсный; CAGE CLAMP; возможность объединения
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина33.4 mm / 1.315 inch
Drilled hole diameter (tolerance)2.2(+ 0.1) мм
Fine-stranded conductor0.2 … 16 mm² / 24 … 6 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 10 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 10 mm²
GTIN4055143374484
Height32 mm / 1.26 inch
Height from the surface27 mm / 1.063 inch
Material groupI
Number of Poles7
Number of connection types1
Number of jumper slots1
Number of levels1
Number of solder pins per potential4
PCB contactTHT
Packaging typeBOX
Pin spacing15 mm (0.591 inch)
Rated current76 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)630 В
Solder pin dimensions1.2 x 1.6 mm
Solder pin length5 мм
Solid conductor0.2 … 16 mm² / 24 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points7
Total number of potentials7
Вес74.698 г
Ширина101.7 mm / 4.004 inch
  • PCB Interconnect
745607/007000, 745 607/007 000
На английском языке: Datasheet Wago 745-607/007-000
