Datasheet Wago 745-838 — Даташит
Стекируемый клеммный блок для печатных плат; 6 мм²; Шаг контактов 7,5 мм; 1-полюсный; CAGE CLAMP; возможность объединения
STACKABLE PCB TERMINAL BLOCK; 6 | |||
| 745-838 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light green |
| Conductor entry angle to the PCB | 45 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 29.1 mm / 1.146 inch |
| Drilled hole diameter (tolerance) | 1.8(+ 0.1) мм |
| Fine-stranded conductor | 0.2 … 6 mm² / 24 … 10 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 4 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 4 mm² |
| Fire load | 0.072 MJ |
| GTIN | 4044918937276 |
| Height | 27.5 mm / 1.083 inch |
| Height from the surface | 23 mm / 0.906 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of jumper slots | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 41 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 1 x 1.4 mm |
| Solder pin length | 4.5 мм |
| Solid conductor | 0.2 … 6 mm² / 24 … 10 AWG |
| Strip length | 11 … 12 mm / 0.43 … 0.47 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 4.752 г |
| Ширина | 9 mm / 0.354 inch |
Серия: 745 (100 из 266)
- 745-362 745-380 745-3801 745-3803 745-3803/999-950 745-3804 745-3807 745-3808 745-381 745-382 745-383 745-384 745-385 745-390 745-391 745-392 745-393 745-394 745-395 745-500 745-501/011-000 745-502/006-000 745-502/011-000 745-503/006-000 745-504/006-000 745-504/011-000 745-505/006-000 745-540 745-545 745-582 745-583 745-584 745-585 745-602/006-000 745-603/006-000 745-604/006-000 745-604/011-000 745-605/006-000 745-605/007-000 745-606/006-000 745-607/007-000 745-631 745-632 745-633 745-634 745-635 745-652/006-000 745-652/007-000 745-652/011-000 745-653/006-000 745-653/007-000 745-654/006-000 745-655/006-000 745-681 745-682 745-683 745-684 745-685 745-801 745-803 745-803/999-950 745-804 745-807 745-808 745-811 745-813 745-813/999-950 745-814 745-817 745-818 745-821 745-823 745-824 745-827 745-828 745-831 745-833 745-834 745-837 745-838 745-841 745-843 745-844 745-847 745-848 745-851/006-000 745-853/006-000 745-854/006-000 745-857/006-000 745-858/006-000 745-871/006-000 745-873/006-000 745-874/006-000 745-877/006-000 745-878/006-000 745-881/006-000 745-883/006-000 745-884/006-000 745-887/006-000 745-888/006-000
- PCB Interconnect
