Datasheet Wago 745-887/006-000 — Даташит
Серия745
Модель745-887/006-000
Стекируемый клеммный блок для печатных плат; 16 мм²; Шаг контактов 20 мм; 1-полюсный; CAGE CLAMP; возможность объединения
Actuation typeOperating tool
Цветgreen-yellow
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина33.4 mm / 1.315 inch
Drilled hole diameter (tolerance)2.2(+ 0.1) мм
Fine-stranded conductor0.2 … 16 mm² / 24 … 6 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 10 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 10 mm²
Fire load0.236 MJ
GTIN4055143555913
Height33.5 mm / 1.319 inch
Height from the surface27 mm / 1.063 inch
Material groupI
Number of Poles1
Number of connection types1
Number of jumper slots1
Number of levels1
Number of solder pins per potential4
PCB contactTHT
Pin spacing20 mm (0.787 inch)
Rated current76 A
Rated impulse voltage (II / 2)12 kV
Rated impulse voltage (III / 2)12 kV
Rated impulse voltage (III / 3)12 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions1.2 x 1.6 mm
Solder pin length6.5 мм
Solid conductor0.2 … 16 mm² / 24 … 6 AWG
Strip length12 … 13 mm / 0.47 … 0.51 Inch
Total number of connection points1
Total number of potentials1
Вес12.61 г
Ширина21.5 mm / 0.846 inch
  • PCB Interconnect
745887/006000, 745 887/006 000
На английском языке: Datasheet Wago 745-887/006-000
