Datasheet Wago 745-1454 — Даташит
Серия745
Модель745-1454
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 15 мм; 4-полюсный; CAGE CLAMP
Элитан
970 ₽
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина29.1 mm / 1.146 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 4 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 4 mm²
Fire load0.556 MJ
GTIN4045454625641
Height27.5 mm / 1.083 inch
Height from the surface23 mm / 0.906 inch
Material groupI
Number of Poles4
Number of connection types1
Number of levels1
Number of solder pins per potential4
PCB contactTHT
Pin spacing15 mm (0.591 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points4
Total number of potentials4
Вес27.786 г
Ширина54.1 mm / 2.13 inch
  • PCB Interconnect
7451454, 745 1454
На английском языке: Datasheet Wago 745-1454
