Datasheet Wago 745-3260 — Даташит
Серия745
Модель745-3260
Клеммная колодка для печатной платы; 4 мм²; Шаг контактов 12,5 мм; 10-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originCH
Габариты: глубина19.4 mm / 0.764 inch
Drilled hole diameter (tolerance)1.5(+ 0.1) мм
Fine-stranded conductor0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fire load0.648 MJ
GTIN4045454001155
Height23 mm / 0.906 inch
Height from the surface19 mm / 0.748 inch
Material groupI
Number of Poles10
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing12.5 mm (0.492 inch)
Rated current32 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions0.8 x 1.2 mm
Solder pin length4 мм
Solid conductor0.08 … 4 mm² / 28 … 12 AWG
Total number of connection points10
Total number of potentials10
Вес30.55 г
Ширина119 mm / 4.685 inch
  • PCB Interconnect
7453260, 745 3260
На английском языке: Datasheet Wago 745-3260
