Datasheet Wago 745-3807 — Даташит
Серия745
Модель745-3807
Стекируемый клеммный блок для печатных плат; 4 мм²; Шаг контактов 5 мм; 1-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgreen-yellow
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина19.4 mm / 0.764 inch
Drilled hole diameter (tolerance)1.5(+ 0.1) мм
Fine-stranded conductor0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fire load0.026 MJ
GTIN4045454001230
Height23 mm / 0.906 inch
Height from the surface19 mm / 0.748 inch
Material groupI
Number of Poles1
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current32 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.8 x 1.2 mm
Solder pin length4 мм
Solid conductor0.08 … 4 mm² / 28 … 12 AWG
Total number of connection points1
Total number of potentials1
Вес1.774 г
Ширина6.5 mm / 0.256 inch
  • PCB Interconnect
7453807, 745 3807
На английском языке: Datasheet Wago 745-3807
