Datasheet Wago 746 — Даташит
Серия746
Datasheet Wago 746
Parameters / Models746-2302
746-2302
746-2303
746-2303
746-2303/000-009
746-2303/000-009
746-2303/000-016
746-2303/000-016
746-2304
746-2304
746-2305
746-2305
746-2305/000-006
746-2305/000-006
746-2305/000-016
746-2305/000-016
746-2306
746-2306
746-2307
746-2307
746-2308
746-2308
746-2308/000-006
746-2308/000-006
746-2308/000-009
746-2308/000-009
746-2309
746-2309
746-2310
746-2310
746-2312
746-2312
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraylight graygreen-yellowgraygraybluegreen-yellowgraygraygraybluelight graygraygraygray
Conductor entry angle to the PCB, °45454545454545454545454545454545
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originPLPLPLPLPLPLPLPLPLPLPLPLPLPLPLPL
Габариты: глубина37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch37 mm / 1.457 inch
Drilled hole diameter (tolerance), мм2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)2.2(+ 0.1)
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²0.5 … 6 mm²
Fire load, MJ0.3010.4230.4080.4090.5450.6670.6410.6430.7890.9111.0330.9920.9931.1551.2771.521
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0V0
GTIN4045454156534404545415655840454542995764050821478799404545415657240454541232604050821256601405082125662540454541565894045454156596404545415660240508214606574050821477631404545415661940454541566264045454156633
Height41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch41.3 mm / 1.623 inch
Height from the surface36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIIIIIIIII
Number of Poles233345556788891012
Number of connection types1111111111111111
Number of levels2222222222222222
Number of solder pins per potential2222222222222222
PCB contactTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHTTHT
Pin spacing7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)7.5 mm (0.295 inch)
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A50505050505050505050505050505050
Rated impulse voltage (II / 2), kV8888888888888888
Rated impulse voltage (III / 2), kV8888888888888888
Rated impulse voltage (III / 3), kV8888888888888888
Rated voltage (II / 2), В1000100010001000100010001000100010001000100010001000100010001000
Rated voltage (III / 2), В1000100010001000100010001000100010001000100010001000100010001000
Rated voltage (III / 3), В800800800800800800800800800800800800800800800800
Solder pin arrangementover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggeredover the entire terminal strip, staggered
Solder pin dimensions1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm1.6 x 1.2 mm
Solder pin length, мм4.44.44.44.44.44.44.44.44.44.44.44.44.44.44.44.4
Solid conductor0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG0.5 … 10 mm² / 20 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points466681010101214161616182024
Total number of potentials233345556788891012
Вес, г17.01824.69824.65424.66532.12439.80439.7439.74947.2354.9162.33662.25162.24770.01677.44292.548
Ширина17.7 mm / 0.697 inch25.2 mm / 0.992 inch25.2 mm / 0.992 inch25.2 mm / 0.992 inch32.7 mm / 1.287 inch40.2 mm / 1.583 inch40.2 mm / 1.583 inch40.2 mm / 1.583 inch47.7 mm / 1.878 inch55.2 mm / 2.173 inch62.7 mm / 2.469 inch62.7 mm / 2.469 inch62.7 mm / 2.469 inch70.2 mm / 2.764 inch77.7 mm / 3.059 inch92.7 mm / 3.65 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 746
