Datasheet Wago 746-2303/000-016 — Даташит
2-проводная клеммная колодка для печатной платы; 10 мм²; Шаг контактов 7,5 мм; 3-полюсный; Push-in CAGE CLAMP
2-CONDUCTOR PCB TERMINAL BLOCK; | |||
746-2303/000-016 Wago | по запросу |
Цвет | green-yellow |
Country of origin | PL |
Габариты: глубина | 37 mm / 1.457 inch |
Drilled hole diameter (tolerance) | 2.2(+ 0.1) мм |
Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 6 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 6 mm² |
Fire load | 0.409 MJ |
GTIN | 4050821478799 |
Height | 41.3 mm / 1.623 inch |
Height from the surface | 36.9 mm / 1.453 inch |
Material group | I |
Number of Poles | 3 |
Number of levels | 2 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 50 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 1.6 x 1.2 mm |
Solder pin length | 4.4 мм |
Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
Total number of connection points | 6 |
Total number of potentials | 3 |
Вес | 24.665 г |
Ширина | 25.2 mm / 0.992 inch |
Серия: 746 (16)
- PCB Interconnect
7462303/000016, 746 2303/000 016
