Datasheet Wago 746-2305/000-016 — Даташит
Клеммная колодка для печатной платы с 2 проводниками; 10 мм²; Шаг контактов 7,5 мм; 5-полюсный; Зажим Push-in CAGE CLAMP
2-CONDUCTOR PCB TERMINAL BLOCK; | |||
| 746-2305 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | green-yellow |
| Conductor entry angle to the PCB | 45 ° |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 37 mm / 1.457 inch |
| Drilled hole diameter (tolerance) | 2.2(+ 0.1) мм |
| Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.5 … 6 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.5 … 6 mm² |
| Fire load | 0.643 MJ |
| GTIN | 4050821256625 |
| Height | 41.3 mm / 1.623 inch |
| Height from the surface | 36.9 mm / 1.453 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 50 A |
| Rated impulse voltage (II / 2) | 8 kV |
| Rated impulse voltage (III / 2) | 8 kV |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 1000 В |
| Rated voltage (III / 3) | 800 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 1.6 x 1.2 mm |
| Solder pin length | 4.4 мм |
| Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 5 |
| Вес | 39.749 г |
| Ширина | 40.2 mm / 1.583 inch |
Серия: 746 (16)
- PCB Interconnect
7462305/000016, 746 2305/000 016
