Datasheet Wago 746-2310 — Даташит
Серия746
Модель746-2310
2-проводная клеммная колодка для печатной платы; 10 мм²; Шаг контактов 7,5 мм; 10-полюсный; Зажим Push-in CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина37 mm / 1.457 inch
Drilled hole diameter (tolerance)2.2(+ 0.1) мм
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load1.277 MJ
GTIN4045454156626
Height41.3 mm / 1.623 inch
Height from the surface36.9 mm / 1.453 inch
Material groupI
Number of Poles10
Number of connection types1
Number of levels2
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current50 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.6 x 1.2 mm
Solder pin length4.4 мм
Solid conductor0.5 … 10 mm² / 20 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points20
Total number of potentials10
Вес77.442 г
Ширина77.7 mm / 3.059 inch
  • PCB Interconnect
7462310, 746 2310
На английском языке: Datasheet Wago 746-2310
