Datasheet Wago 769-635/003-036 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; Шаг контактов 5 мм; 5-пол.
| THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 769-635/003-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 18.3 mm / 0.72 inch |
| Fire load | 0.142 MJ |
| GTIN | 4050821272700 |
| Height from the surface | 22.2 mm / 0.874 inch |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 5 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm / 0.197 inch |
| Product Group | 18 (X-COM-System) |
| Rated current | 32 A |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (III / 2) | 500 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin dimensions | Solder pin 1 x 1 mm |
| Total number of potentials | 5 |
| Вес | 6.255 г |
| Ширина | 39.7 mm / 1.563 inch |
Серия: 769 (100 из 460)
- 769-611/001-000 769-611/002-000 769-611/004-000 769-611/005-000 769-611/006-000 769-612 769-612/001-000 769-612/002-000 769-612/004-000 769-612/005-000 769-612/006-000 769-613 769-613/001-000 769-613/002-000 769-613/004-000 769-613/005-000 769-613/006-000 769-614 769-614/001-000 769-614/002-000 769-614/004-000 769-614/005-000 769-614/006-000 769-615 769-615/001-000 769-615/002-000 769-615/004-000 769-615/005-000 769-615/006-000 769-632 769-632/000-036 769-632/003-000 769-632/003-036 769-632/004-000 769-632/007-000 769-633 769-633/000-036 769-633/003-000 769-633/003-036 769-633/004-000 769-633/007-000 769-634 769-634/000-036 769-634/003-000 769-634/003-036 769-634/004-000 769-634/007-000 769-635 769-635/000-036 769-635/003-000 769-635/003-036 769-635/004-000 769-635/007-000 769-636 769-636/003-000 769-636/003-036 769-636/004-000 769-636/007-000 769-637 769-637/003-000 769-637/004-000 769-637/007-000 769-638 769-638/003-000 769-638/004-000 769-638/007-000 769-639 769-639/003-000 769-639/004-000 769-639/007-000 769-640 769-640/003-000 769-640/004-000 769-640/007-000 769-641 769-641/003-000 769-641/004-000 769-641/007-000 769-642 769-642/003-000 769-642/004-000 769-642/007-000 769-643 769-643/003-000 769-643/004-000 769-643/007-000 769-644 769-644/003-000 769-644/004-000 769-644/007-000 769-645 769-645/003-000 769-645/004-000 769-645/007-000 769-662 769-662/003-000 769-662/004-000 769-663 769-663/003-000 769-663/004-000
769635/003036, 769 635/003 036
