Datasheet Wago 769-669/003-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; угловые; зажимное кольцо; Шаг контактов 5 мм; 9-пол.
| THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 769-669/003-000 Wago | 481 ₽ | ||
| 769-669/003-000 Wago | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 22.2 mm / 0.874 inch |
| Fire load | 0.213 MJ |
| GTIN | 4044918396974 |
| Height from the surface | 18.3 mm / 0.72 inch |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 9 |
| Number of levels | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm / 0.197 inch |
| Product Group | 18 (X-COM-System) |
| Rated current | 32 A |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (III / 2) | 500 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin dimensions | Solder pin 1 x 1 mm |
| Total number of potentials | 9 |
| Вес | 10.355 г |
| Ширина | 59.7 mm / 2.35 inch |
Серия: 769 (100 из 460)
- 769-633/000-036 769-633/003-000 769-633/003-036 769-633/004-000 769-633/007-000 769-634 769-634/000-036 769-634/003-000 769-634/003-036 769-634/004-000 769-634/007-000 769-635 769-635/000-036 769-635/003-000 769-635/003-036 769-635/004-000 769-635/007-000 769-636 769-636/003-000 769-636/003-036 769-636/004-000 769-636/007-000 769-637 769-637/003-000 769-637/004-000 769-637/007-000 769-638 769-638/003-000 769-638/004-000 769-638/007-000 769-639 769-639/003-000 769-639/004-000 769-639/007-000 769-640 769-640/003-000 769-640/004-000 769-640/007-000 769-641 769-641/003-000 769-641/004-000 769-641/007-000 769-642 769-642/003-000 769-642/004-000 769-642/007-000 769-643 769-643/003-000 769-643/004-000 769-643/007-000 769-644 769-644/003-000 769-644/004-000 769-644/007-000 769-645 769-645/003-000 769-645/004-000 769-645/007-000 769-662 769-662/003-000 769-662/004-000 769-663 769-663/003-000 769-663/004-000 769-664 769-664/003-000 769-664/004-000 769-665 769-665/003-000 769-665/004-000 769-666 769-666/003-000 769-666/004-000 769-667 769-667/003-000 769-667/004-000 769-668 769-668/003-000 769-668/004-000 769-669 769-669/003-000 769-669/004-000 769-670 769-670/003-000 769-670/004-000 769-671 769-671/003-000 769-671/004-000 769-672 769-672/003-000 769-672/004-000 769-673 769-673/003-000 769-673/004-000 769-674 769-674/003-000 769-674/004-000 769-675 769-675/003-000 769-675/004-000
769669/003000, 769 669/003 000
