Datasheet Wago 770-834 — Даташит
Штекер для печатных плат; прямые; 4-пол.; Код. A
Купить 770-834 на РадиоЛоцман.Цены — от 3.65 до 49 ₽26 предложений от 18 поставщиков Аксессуары Соединителей, CONN SOCKET 26-30AWG GOLD CRIMP | |||
| 770834-4 TE Connectivity | от 7.67 ₽ | ||
| 1-770834-1 TE Connectivity | 15 ₽ | ||
| 770834-1 TE Connectivity | по запросу | ||
| 770834-4 TE Connectivity | по запросу | ||
| Coding | A |
| Цвет | white |
| Connector connection type | for PCBs |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 14.6 mm / 0.575 inch |
| Design | straight |
| Drilled hole diameter (tolerance) | 1.5(+ 0.1 ... - 0.1) мм |
| Fire load | 0.277 MJ |
| GTIN | 4044918511568 |
| Ground function | with preceding GND contact |
| Height | 29.5 mm / 1.161 inch |
| Height from the surface | 26 mm / 1.024 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ 2|L 1|L' |
| Mating direction to the PCB | 90 ° |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ 2/L 1/L' |
| Product Group | 20 (WINSTA) |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solder pin arrangement | 2 in-line solder pins/pole |
| Solder pin dimensions | 1 x 0.8 mm |
| Solder pin length | 3.5 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 4 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 11.731 г |
| Ширина | 37 mm / 1.457 inch |
Серия: 770 (100 из 608)
- 770-764/071-000 770-764/072-000 770-764/073-000 770-765 770-765/073-000 770-773 770-773/071-000 770-773/073-000 770-774 770-774/071-000 770-774/072-000 770-774/073-000 770-775 770-775/073-000 770-783 770-783/081-000 770-783/082-000 770-784 770-784/081-000 770-785 770-785/080-000 770-785/082-000 770-793 770-793/081-000 770-793/082-000 770-794 770-794/081-000 770-795 770-795/080-000 770-795/082-000 770-803 770-803/011-000 770-804 770-804/011-000 770-805 770-805/011-000 770-813 770-813/011-000 770-814 770-814/011-000 770-815 770-815/011-000 770-823 770-823/011-000 770-824 770-824/011-000 770-825 770-825/011-000 770-833 770-833/011-000 770-834 770-834/011-000 770-835 770-835/011-000 770-843 770-843/011-000 770-843/011-000/060-000 770-843/011-000/062-000 770-843/060-000 770-843/062-000 770-844 770-844/011-000 770-844/011-000/060-000 770-844/011-000/062-000 770-844/011-000/064-000 770-844/060-000 770-844/062-000 770-844/064-000 770-845 770-845/011-000 770-845/011-000/060-000 770-845/011-000/062-000 770-845/011-000/064-000 770-845/060-000 770-845/062-000 770-845/064-000 770-853 770-853/011-000 770-853/011-000/060-000 770-853/011-000/062-000 770-853/060-000 770-853/062-000 770-854 770-854/011-000 770-854/011-000/060-000 770-854/011-000/062-000 770-854/011-000/064-000 770-854/060-000 770-854/062-000 770-854/064-000 770-855 770-855/011-000 770-855/011-000/060-000 770-855/011-000/062-000 770-855/011-000/064-000 770-855/060-000 770-855/062-000 770-855/064-000 770-863 770-863/011-000
