Datasheet Wago 770-3115/011-000 — Даташит
Штекер для печатных плат; угловые; 5-пол.; Код. I
PLUG FOR PCBS ANGLED 5-POLE, BLU | |||
| 770-3115/011-000 Wago | 856 ₽ | ||
| 770-3115/011-000 Wago | по запросу | ||
| Coding | I |
| Цвет | blue |
| Connector connection type | for PCBs |
| Contact material | Copper or copper alloy, surface-treated |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Degree of protection | IP20 |
| Габариты: глубина | 26 mm / 1.024 inch |
| Design | angled |
| Drilled hole diameter (tolerance) | 1.5(+ 0.1 ... - 0.1) мм |
| Fire load | 0.208 MJ |
| GTIN | 4045454819699 |
| Ground function | with preceding GND contact |
| Height | 18.1 mm / 0.713 inch |
| Height from the surface | 14.6 mm / 0.575 inch |
| Locking lever | да |
| Locking of plug-in connection | locking lever |
| Marking | N ⏚ L DA- DA+ |
| Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 10 mm (0.394 inch) |
| Potential marking | N ⏚ L DA- DA+ |
| Rated current | 25 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 400 В |
| Retention force of a plug-in connection | when locked: > 80N |
| Solder pin arrangement | 2 in-line solder pins/pole |
| Solder pin dimensions | 1 x 0.8 mm |
| Solder pin length | 3.5 мм |
| Surrounding air (operating) temperature | -35 … 85 °C |
| Total number of potentials | 5 |
| Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
| Вес | 10.919 г |
| Ширина | 47 mm / 1.85 inch |
Серия: 770 (100 из 608)
- 770-255 770-255/060-000 770-255/062-000 770-255/064-000 770-262 770-263 770-263/071-000 770-263/073-000 770-264 770-264/071-000 770-264/072-000 770-264/073-000 770-265 770-265/073-000 770-272 770-273 770-273/071-000 770-273/073-000 770-274 770-274/071-000 770-274/072-000 770-274/073-000 770-275 770-275/073-000 770-282 770-282/080-000 770-282/082-000 770-283 770-283/081-000 770-283/082-000 770-284 770-284/081-000 770-285 770-285/080-000 770-285/082-000 770-292 770-292/080-000 770-292/082-000 770-293 770-293/081-000 770-293/082-000 770-294 770-294/081-000 770-295 770-295/080-000 770-295/082-000 770-305 770-3105 770-3105/011-000 770-3115 770-3115/011-000 770-315 770-317 770-318 770-319 770-320 770-321 770-325 770-335 770-337 770-338 770-339 770-340 770-341 770-354 770-360 770-382 770-383 770-401 770-405 770-408 770-415 770-418 770-425 770-428 770-435 770-438 770-450 770-450/000-001 770-450/000-002 770-450/000-005 770-450/000-006 770-450/000-012 770-5001/100-000 770-502/041-000 770-502/042-000 770-503 770-503/021-000 770-503/023-000 770-503/032-000 770-503/035-000 770-503/038-000 770-504 770-504/023-000 770-505 770-505/021-000 770-505/023-000 770-506/029-000 770-507/047-000 770-512/041-000
7703115/011000, 770 3115/011 000
