Datasheet Wago 804-102 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 5 мм; 2-полюсный; Вставной зажим CAGE CLAMP
Купить 804-102 на РадиоЛоцман.Цены — от 90 до 85 736 ₽19 предложений от 8 поставщиков Настольный источник питания, Power Supply, 1CH, 32V, 10A, Prog | |||
| 804-102 | от 193 ₽ | ||
| 804-102 Wago | 219 ₽ | ||
| HMC8041.02 Rohde&Schwarz | 85 736 ₽ | ||
| 804-102/000-012 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 15 mm / 0.591 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.037 MJ |
| GTIN | 4044918514934 |
| Height | 18.1 mm / 0.713 inch |
| Height from the surface | 14.5 mm / 0.571 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.8 x 0.6 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.25 … 2.5 mm² / 20 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Вес | 2.208 г |
| Ширина | 11.5 mm / 0.453 inch |
Серия: 804 (30)
- PCB Interconnect
