Datasheet Wago 804 — Даташит
Производитель | Wago |
Серия | 804 |
![]() 19 предложений от 8 поставщиков Настольный источник питания, Power Supply, 1CH, 32V, 10A, Prog | |||
804-102 Wago | от 260 ₽ | ||
HMC8041.02 Rohde&Schwarz | 85 537 ₽ | ||
A804102 | по запросу | ||
804-102/000-012 Wago | по запросу |
Parameters / Models | 804-102![]() | 804-102/000-051![]() | 804-103![]() | 804-104![]() | 804-104/000-004![]() | 804-105![]() | 804-106![]() | 804-107![]() | 804-108![]() | 804-109![]() | 804-110![]() | 804-111![]() | 804-112![]() | 804-113![]() | 804-114![]() | 804-115![]() | 804-116![]() | 804-302![]() | 804-303![]() | 804-304![]() | 804-304/000-012![]() | 804-305![]() | 804-306![]() | 804-307![]() | 804-308![]() | 804-309![]() | 804-309/000-008![]() | 804-310![]() | 804-311![]() | 804-312![]() |
Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | |
Clamping spring material | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | Chrome nickel spring steel (CrNi) | |
Цвет | gray | pink | gray | gray | black | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | gray | orange | gray | gray | gray | gray | gray | gray | gray | gray | |
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | |
Contact material | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | Electrolytic copper (Ecu) | |
Contact plating | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | tin-plated | |
Country of origin | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | CH | |
Габариты: глубина | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.531 inch | 15 mm / 0.591 inch | 15 mm / 0.531 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | 15 mm / 0.591 inch | |
Drilled hole diameter (tolerance), мм | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | 1.1(+ 0.1) | |
Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | 0.25 … 2.5 mm² / 22 … 12 AWG | |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | 0.25 … 1.5 mm² | |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | 0.25 … 2.5 mm² | |
Fire load, MJ | 0.037 | 0.052 | 0.067 | 0.082 | 0.097 | 0.112 | 0.127 | 0.142 | 0.157 | 0.172 | 0.187 | 0.202 | 0.217 | 0.232 | 0.247 | 0.044 | 0.066 | 0.088 | 0.11 | 0.132 | 0.154 | 0.176 | 0.198 | 0.22 | 0.242 | 0.264 | ||||
Flammability class per UL94 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | V0 | |
GTIN | 4044918514934 | 4055143378710 | 4044918514972 | 4044918515009 | 4055143248174 | 4044918515030 | 4044918515061 | 4044918515092 | 4044918515122 | 4044918515153 | 4044918515184 | 4044918515214 | 4044918515245 | 4044918515276 | 4044918515306 | 4044918515337 | 4044918515368 | 4044918515399 | 4044918515405 | 4044918515412 | 4055143278911 | 4044918515429 | 4044918515436 | 4044918515443 | 4044918515450 | 4044918515467 | 4044918515474 | 4044918515481 | 4044918515498 | |
Height | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | 18.1 mm / 0.713 inch | |
Height from the surface | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | 14.5 mm / 0.571 inch | |
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | |
Legend (ratings) | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | (III / 2) ≙ Overvoltage category III / Pollution degree 2 | |
Limit temperature range | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | -60 … +105 °C | |
Material group | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | I | |
Number of Poles | 2 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |
Number of connection types | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Number of solder pins per potential | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | |
PCB contact | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | THT | |
Packaging type | BOX | BOX | BOX | |||||||||||||||||||||||||||
Pin spacing | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 5 mm (0.197 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | 7.5 mm (0.295 inch) | |
Product Group | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | 4 (Printed Circuit) | ||||
Rated current, A | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | |
Rated impulse voltage (II / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |
Rated impulse voltage (III / 2), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |
Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |
Rated voltage (II / 2), В | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | 630 | |
Rated voltage (III / 2), В | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | |
Rated voltage (III / 3), В | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | 320 | |
Solder pin arrangement | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | over the entire terminal strip, staggered | |
Solder pin dimensions | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | 0.8 x 0.6 mm | |
Solder pin length, мм | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | |
Solid conductor | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | 0.25 … 2.5 mm² / 20 … 12 AWG | |
Strip length | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | 10 … 11 mm / 0.39 … 0.43 Inch | |
Total number of connection points | 2 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |
Total number of potentials | 2 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 2 | 3 | 4 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |
Вес, г | 2.208 | 2.227 | 3.192 | 4.176 | 5.114 | 5.16 | 6.144 | 7.128 | 8.112 | 9.096 | 10.08 | 11.064 | 12.048 | 13.032 | 14.016 | 15 | 15.984 | 2.427 | 3.63 | 4.833 | 4.815 | 6.036 | 7.239 | 8.442 | 9.645 | 10.848 | 12.051 | 13.254 | 14.457 | |
Ширина | 11.5 mm / 0.453 inch | 11.5 mm / 0.453 inch | 16.5 mm / 0.65 inch | 21.5 mm / 0.846 inch | 21.5 mm / 0.846 inch | 26.5 mm / 1.043 inch | 31.5 mm / 1.24 inch | 36.5 mm / 1.437 inch | 41.5 mm / 1.634 inch | 46.5 mm / 1.831 inch | 51.5 mm / 2.028 inch | 56.5 mm / 2.224 inch | 61.5 mm / 2.421 inch | 66.5 mm / 2.618 inch | 71.5 mm / 2.815 inch | 76.5 mm / 3.012 inch | 81.5 mm / 3.209 inch | 14 mm / 0.551 inch | 21.5 mm / 0.846 inch | 29 mm / 1.142 inch | 29 mm / 1.142 inch | 36.5 mm / 1.437 inch | 44 mm / 1.732 inch | 51.5 mm / 2.028 inch | 59 mm / 2.323 inch | 66.5 mm / 2.618 inch | 74 mm / 2.913 inch | 81.5 mm / 3.209 inch | 89 mm / 3.504 inch |
Серия: 804 (30)
- PCB Interconnect
