Datasheet Wago 804-310 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 7,5 мм; 10-полюсный; Зажим Push-in CAGE CLAMP
PCB TERMINAL BLOCK; PUSH-BUTTON; | |||
| 804-310 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 15 mm / 0.591 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.22 MJ |
| GTIN | 4044918515474 |
| Height | 18.1 mm / 0.713 inch |
| Height from the surface | 14.5 mm / 0.571 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire terminal strip, staggered |
| Solder pin dimensions | 0.8 x 0.6 mm |
| Solder pin length | 3.6 мм |
| Solid conductor | 0.25 … 2.5 mm² / 20 … 12 AWG |
| Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Вес | 12.051 г |
| Ширина | 74 mm / 2.913 inch |
Серия: 804 (30)
- PCB Interconnect
