Datasheet Wago 805-106 — Даташит
Серия805
Модель805-106
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 6-полюсный; Зажим Push-in CAGE CLAMP
LAN 10/100 Base - TX Voice Over IP Magnetics Module
LifeElectronics
Filtran
МосЧип
AD8051_06
Actuation typePush-button
Цветgray
Contact platingtin-plated
Country of originPL
Габариты: глубина13.6 mm / 0.535 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.059 MJ
GTIN4045454731540
Height13.7 mm / 0.539 inch
Height from the surface10.5 mm / 0.413 inch
Material groupI
Number of Poles6
Number of connection types1
Number of levels1
Number of test slots1
PCB contactTHT
Rated current17.5 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)250 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.75 mm
Solder pin length3.2 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points6
Total number of potentials6
Вес2.796 г
Ширина22.5 mm / 0.886 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 805-106
