Datasheet Wago 805-303/200-604 — Даташит
Серия805
Модель805-303/200-604
Клеммная колодка THR PCB; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 3-полюсный; Вставной зажим CAGE CLAMP
LifeElectronics
P8-05-303
Actuation typePush-button
Цветblack
Contact platingtin-plated
Country of originCH
Габариты: глубина13.6 mm / 0.535 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.047 MJ
Flammability class per UL94V2
GTIN4050821403753
Height12.7 mm / 0.5 inch
Height from the surface10.5 mm / 0.413 inch
Insulating materialPolyamide 46 (PA 46)
Material groupIII a
Number of Poles3
Number of connection types1
Number of levels1
PCB contactTHR
Plated through-hole diameter (THR)1.1 (+ 0.1) мм
Rated current17.5 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)200 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.75 mm
Solder pin length2.2 мм
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points3
Total number of potentials3
Вес1.962 г
Ширина12 mm / 0.472 inch
  • PCB Interconnect
805303/200604, 805 303/200 604
На английском языке: Datasheet Wago 805-303/200-604
