Datasheet Wago 805-316 — Даташит
Клеммная колодка для печатной платы; Кнопка; 1,5 мм²; Шаг контактов 3,5 мм; 16-полюсный; Зажим Push-in CAGE CLAMP
AVX Advanced Ceramic Capacitors for Power Supply, High Voltage and Tip and Ring Applications | |||
UPD805316 | по запросу | ||
805/316 | по запросу | ||
SM-C-805316 AVX | по запросу |
Actuation type | Push-button |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 13.6 mm / 0.535 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
GTIN | 4055143388641 |
Height | 13.7 mm / 0.539 inch |
Height from the surface | 10.5 mm / 0.413 inch |
Material group | I |
Number of Poles | 16 |
Number of levels | 1 |
PCB contact | THT |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 3.2 мм |
Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 16 |
Total number of potentials | 16 |
Вес | 7.526 г |
Ширина | 57.5 mm / 2.264 inch |
Серия: 805 (100 из 104)
- 805-106 805-106/000-006 805-107 805-108 805-109 805-110 805-111 805-112 805-113 805-114 805-115 805-116 805-117 805-118 805-119 805-120 805-121 805-122 805-123 805-124 805-152 805-153 805-154 805-155 805-156 805-157 805-158 805-159 805-160 805-161 805-162 805-163 805-164 805-165 805-166 805-167 805-168 805-169 805-170 805-171 805-172 805-173 805-174 805-302 805-302/200-604 805-303 805-303/200-604 805-304 805-304/200-604 805-305 805-305/200-604 805-306 805-306/200-604 805-306/200-604/997-406 805-307 805-307/200-604 805-307/200-604/997-406 805-308 805-308/000-023 805-308/200-604 805-308/200-604/997-406 805-309 805-310 805-311 805-312 805-313 805-314 805-315 805-316 805-317 805-318 805-319 805-320 805-321 805-322 805-323 805-324 805-352 805-353 805-354 805-355 805-356 805-357 805-358 805-359 805-360 805-361 805-362 805-363 805-364 805-365 805-366 805-367 805-368 805-369 805-370 805-371 805-372 805-373 805-374
- PCB Interconnect
